It is currently Tue Nov 17, 2026 6:42 am
PostPosted: Thu Apr 27, 2006 6:57 pm
HI,
I'm new to Mopars and am having lots of fun with a 62 Valiant,
(added bucket seats, Super Six set up and electronic ignition).
And out of the blue, I pushed the reverse button in and it won't come back up. What's that all about?
Mike
60 Red V200 Valiant & 62 Green V200 Valiant
 Post subject: push button
PostPosted: Thu Apr 27, 2006 7:44 pm
hopefully the plastic lever just came out of the prongs that hold it into the switch selector--Take the dash cover off & use a light source to check & see exactly what happened.. if nothing is broke just line it back up & push it back in place---
you might want to squeeze the prongs together just a little to help hold them-- (if they do not hole the lever tight)
Good luck
 Post subject: weak spring
PostPosted: Thu Apr 27, 2006 8:03 pm
On my daughter's 61 it was a broken spring in the push button box.
It was part of the mechanism that was supposed to put the R button back to the front when N was pushed. I bought a 63 dart button box and used the spring from it as much of the innards were the same.
I would guess that a hard to move (dirty or kinked) shift cable might also have the same affect.
 Post subject: Thanks folks
PostPosted: Fri Apr 28, 2006 7:14 am
I will look into this tonight and let you know !!!
PostPosted: Fri Apr 28, 2006 1:18 pm
cool, i guess i gotta take that box out and have a look too, my Neutral button's stuck
Allen
1962 Valiant V-200
170 C.I. Super Six, HEI, Dutra Duals
 Post subject: Fixed !!!!!!!!!!!
PostPosted: Sun Apr 30, 2006 5:36 pm
Everyone was right, the reverse button slipped out of the connector. I remated the two and it works fine again.
THANKS
