It is currently Tue Nov 24, 2026 2:20 pm
 Post subject: paging slantsixdan
PostPosted: Sat May 06, 2006 7:10 pm
I'm probably going to be running out to a wrecking yard this week to get a windshield and rear wiper motor for my talon and was wondering what year Chevy’s I could pull a hei ignition system out of
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Sun May 07, 2006 3:33 am
You can find them in most gm cars/trucks from the mid 70´s to mid 80´s, maybe a few later too.
It does not have to be a chevy, every gm brand used the hei.
Just look at it, and see if it has 4 connectors, not 7 (or what number the others had)
PostPosted: Sun May 07, 2006 4:33 am
If it were me, I would also get one of the HEI "E" coils. These are the ign coils that are not mounted in the distributer cap.
PostPosted: Sun May 07, 2006 8:56 am
ok so i should be in good shape if i can find a 83 or 84 gm truck
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Sun May 07, 2006 9:59 am
Yes, or caprice, malibu, or whatever...vans...
PostPosted: Sun May 07, 2006 10:45 am
Yep, just start popping distributor caps off GM vehicles, and when you find a 4-pin module, grab it out of the distributor. The advice to get an external-mount HEI coil is good—do that.
PostPosted: Sun May 07, 2006 10:48 am
Car Model: '23 T-bucket
Hey! Don't forget to get the little plugs that go on the module, too.
I get the feeling from your first post that you're looking to get the whole distributor. (Maybe I'm mistaken) If that's the case, you don't need it....just the module and plugs from inside, plus the external mount coil.
Roger
PostPosted: Sun May 07, 2006 9:56 pm
ok thanks guys
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 4 guests
