It is currently Sun Nov 22, 2026 10:08 pm
PostPosted: Mon May 01, 2006 10:25 am
I just pulled the harmonic balancer from my '72 Duster (forged crank). It is completely different from my '80 (cast crank) harmonic balancer. I thought both engines were internally balanced. Why the difference?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Mon May 01, 2006 11:12 am
Why the difference?
The cast crank is lighter than the forged crank by a couple lbs...
I have heard there is no ill effect when using a late damper on an early motor other than you need the matching timing cover...
PostPosted: Mon May 01, 2006 11:48 pm
Check out this harmonic balancer some guy named Maddog is selling:
Romac Harmonic Balancer
Cory
-'72 Valiant Sedan, Stock (For Now)
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 10 guests
