| engine help/ new member https://slantsix.org/forum/viewtopic.php?t=17391 |
| Author: | amoshogg [ Wed May 03, 2006 1:23 pm ] |
| Post subject: | engine help/ new member |
hello, i am new to this forum and i am experiencing several problems with my 1985 225 /6. first: on a cold start engine starts, then stalls almost imediatly. requiring wot to warm up. after engine is at operating temperature, it has a very noticeable miss, shaking, very sluggish acceleration( accelerator to floor, 35 to55mph in 2.5 minutes) has new plugs & wires, rotor, distributor cap, fuel filter/lines, air filter, pcv valve, breather, and ignition coil. also, is it possible to remove the egr valve and install a cover plate in its place? any help would be greatly appreciated. thanks, amos |
| Author: | Reed [ Wed May 03, 2006 1:42 pm ] |
Hello and welcome! First off, does you truck have a lean burn or spark control computer? If so, I would suspect the computer. It sounds like your choke is misadjusted and malfuntioning, and it also sounds like you have a vacuum leak. I would check your choke pulloff diaphragm and your vacuum advance pod on the distributor for leaks. |
| Author: | amoshogg [ Wed May 03, 2006 6:08 pm ] |
it has the holley 6145 feedback carb. i've always had trouble with this carb, either not having enough power, stalling or the like, since it was new. checked all vacuum lines/hoses-tight. carb bolts are tight, no leaks that i know of. a local mechanic told me that the choke stove was bad. any clues? by the way, the truck has sat for the past 4 years, with only an occasional cranking. is it possible that the float or needle valve is sticking? also, i would like to convert to possibly a 2bbl carter bbd carb w/ intake/header & maybe a cam. does anyone have advice in this direction, or where i can get these parts? i have electronic ignition, what does the vacuum advance pod, look like? sorry for long post, thanks, amos |
