| spark plug tubes https://slantsix.org/forum/viewtopic.php?t=17409 |
| Author: | oibrownskin [ Thu May 04, 2006 7:05 pm ] |
| Post subject: | spark plug tubes |
Is it necesary to replace the spark plug tubes (the metal sleeves) when rebuilding an engine? I know there are supposed to be small o-rings that accompany them. I have a '66 225 that I am rebuilding and trying to do a good job with it. taking my time, but I am not building a race motor, just something with a tad more gusto (.060 over with CompCams 252 cam). So replace spark plug sleeves or not necessary? Caesar |
| Author: | Pierre [ Thu May 04, 2006 7:19 pm ] |
Naw, as long as they aren't beat up I don't see why. Inspect the chamber end of them to make sure they are flat and don't have any sharp edges. If they do file them flat and clean up any metal powder so it doesn't enter the engine. The seals are availible aftermarket as well, felpro ES12794. Just to be clear - these seal the tube to the outside of the head, there is no o-ring that seals it to the inside of the head. That is done by the spark plug pinching the sleeve between it and the head. |
| Author: | argentina-slantsixer [ Fri May 05, 2006 2:28 am ] |
I got them tubes as a set from ebay... at the very reasonable cost of $20 plus shipping. Gonna see if I have seller's ID so I can pass it on to you. |
| Author: | Otto [ Fri May 05, 2006 4:10 am ] |
I believe this is the item on ebay if your talking about the rings and not the tubes. http://cgi.ebay.com/ebaymotors/NOS-MoPa ... enameZWD1V |
| Author: | argentina-slantsixer [ Fri May 05, 2006 4:43 am ] |
Quote: I believe this is the item on ebay if your talking about the rings and not the tubes.
no I'm talkin bout the tubes themselves.
| Author: | oibrownskin [ Fri May 05, 2006 12:22 pm ] |
| Post subject: | all helpful |
all that info was helpful. I appreciate it caesar |
| Author: | emsvitil [ Fri May 05, 2006 1:32 pm ] |
http://cgi.ebay.com/ebaymotors/NOS-MoPa ... enameZWD1V That's ridiculous........... |
| Author: | Charrlie_S [ Fri May 05, 2006 2:00 pm ] |
Quote: Quote: I believe this is the item on ebay if your talking about the rings and not the tubes.
| Author: | emsvitil [ Fri May 05, 2006 2:45 pm ] |
Quote: Quote: Quote: I believe this is the item on ebay if your talking about the rings and not the tubes.
http://cgi.ebay.com/ebaymotors/NOS-MoPa ... enameZWD1V That's ridiculous........... Doesn't say seal kit, so that's $9.95 each...........which is ridiculous..... It's $3.49 a set at Rock Auto (plus shipping, but I wouldn't order it alone) |
| Author: | Pierre [ Fri May 05, 2006 3:10 pm ] |
Ooofff... picutre is of one seal, no where does he use plural "seals" anywhere, methinks it is for a single seal. |
| Author: | GTS225 [ Fri May 05, 2006 3:38 pm ] |
C'mon you guys! Ain't you been watching the B-J auctions?! Everybody knows anything Mopar is selling for premium prices, so the parts automatically get more expensive! Roger |
| Author: | slafolle [ Fri May 05, 2006 4:04 pm ] |
Keep in mind, if you get an engine rebuild kit or a gasket kit, it should include the tube gaskets. Also don't forget to cut metal ring off the spark plugs before installing them. I always forget that. Steve 1966 Dart GT |
| Author: | emsvitil [ Fri May 05, 2006 4:41 pm ] |
Quote: Also don't forget to cut metal ring off the spark plugs before installing them. I always forget that.
I never cut them off............I unscrew them |
| Author: | oibrownskin [ Fri May 05, 2006 8:20 pm ] |
| Post subject: | metal ring/washer |
I am supposed to remove that metal washer/ring that is on the threaded side of the spark plug? I never knew that. What is the reason behind this? Caesar |
| Author: | emsvitil [ Fri May 05, 2006 8:49 pm ] |
| Post subject: | Re: metal ring/washer |
Quote: I am supposed to remove that metal washer/ring that is on the threaded side of the spark plug? I never knew that. What is the reason behind this?
Caesar 60-62 use the tubes and the washers 63up (until there's no tubes) use just the tubes. The tube takes the place of the washer/seal for 63up |
