It is currently Mon Nov 23, 2026 6:28 pm
 Post subject: losing without linkage
PostPosted: Thu May 04, 2006 11:18 am
So I thew a 390 cfm carb in and a header, and she runs great! but one problem: I have to manually shift the automatic 904 tranny. its a 4 speed... I can shift btwn 1-2-D (3-4) so I can't control the 3-4 transition and it always shifts pre-maturely (quickly through all gears while in D).
Any ideas on where I can get kickdown linkage? or can I adjust the shift points enough w/out it?
thanks for the help -BS
PostPosted: Thu May 04, 2006 11:26 am
Well, you can get a lokar kickdown linkage, or try this
Since you have a header the Lokar would probably be easiest, but if you are running an offy intake with the holes for the exaust manifold bolts you could try to mock something up using the one barrel kickdown or a two barrel kickdown.
 Post subject: 3-4?
PostPosted: Thu May 04, 2006 11:27 am
If you have an A-904 then you only have 1-2-3...if you chose to replace the old 904 with a 1978+ A-904 then the "4" shift might be the lockup torque convertor kicking in...
Without the kickdown the tranny will not like you for long, unless you tied the kickdown lever back, then it might like you then expire.
Your kickdown linkage solution is the Lokar Kickdown cable, worth a few $$$ and fairly easy to install.
PostPosted: Thu May 04, 2006 11:50 am
well I thought it was a 904. maybe its not. it has 1-2-D (N-R-P) on the column and i could swear that it shifts a 4th time after i put it in D. I'll check when I get home what trans it is. I've been driving it like this for about 1000 mi so far, I hope I haven't hurt it :( ...ps: part number for the Lokar? I saw a bunch of different ones-no mopar
PostPosted: Thu May 04, 2006 2:23 pm
Type this into the summit search:
LOK-KD-2904HT for the cable
LOK-SRK-4000 for the bracket
PostPosted: Thu May 04, 2006 6:16 pm
great
thanks
-bs
