| Mixture Screw in Holley 1920. https://slantsix.org/forum/viewtopic.php?t=17414 |
| Author: | Avenger2040 [ Fri May 05, 2006 6:10 am ] |
| Post subject: | Mixture Screw in Holley 1920. |
Just to remember because I´m pretty bad making carburations, to make the mixture lean (minus gas use), the mixture screw must be bolt in right?, if you unbolt it, it makes the mixture rich (more gas use). Sorry for this kind of stupid questions, but I really know nothing about carbs. |
| Author: | SlantSixDan [ Fri May 05, 2006 7:34 am ] |
Not a stupid question! You're right: Turn the mixture screw clockwise (inward) and you make the mixture leaner—less gas. Turn it anticlockwise (outward) and you make the mixture richer—more gas. |
| Author: | Avenger2040 [ Fri May 05, 2006 9:55 am ] |
Thanks Dan! |
