It is currently Mon Nov 23, 2026 9:11 pm
PostPosted: Fri May 05, 2006 10:06 am
My 1973 Dart Swinger has a blown block, So obviously I need a different one. A-904 auto, 8 1/4 rear end.
A local shop is going to rebuild my motor using my head (1973), and he says he has about 3 blocks at his shop, and when I bring my engine in he will match it up with the best one. I also have a super six manifold and carter BBD from a 77 Volare Station Wagon that needs a rebuild.
I am planning on buying a rebuilt Carter BBD 8087-s from a local shop that has one that has been rebuilt and rebushed. Then rebuliding the one I have and experimenting with different set ups over time. I have never rebuilt a carb myself, so to try and rebuild it myself and put it on a new engine would just create one more potential problem to diagnose.
My questions
1) Are there any year blocks I should not use, or are better than others? I assume the guy at the shop will "match" it like he says, but the better informed I am now, the less chance I have of being screwed later.
2) Should any BBD from a 77-78 slant six work with my future setup? I don't know much about "lean burn", and I don't know if the rebuilt BBD came from a car that had it. Is there a difference between carbs that came from lean burn or not lean burn cars?
3) do you foresee any problems with the setup I am planning?
4) Are different cams in different year blocks? Is there a best cam for the super six setup like I am going to use?
Sorry about all the questions, and thanks for any input you can give me.
 Post subject: Match and mix...
PostPosted: Fri May 05, 2006 11:28 am
For your car any block up to 1976 would be OK as long as:
You use a 1968-1976 forged crank like your engine...
Another thing to be wary of is you can also use the 1976+ cast crank engines, they bolt in place, run about the same, but use some different bearings, etc...
PostPosted: Fri May 05, 2006 11:40 am
I would go with a block from 68 to 74. I think I heard someone say that you can use afb jets and metering rods in a bbd, dont quote me on that. If you have time look at the old trucks and van for their 2bbl intake and carb set up they dont run that extra sensor behind the vaccum tree.
PostPosted: Fri May 05, 2006 3:00 pm
Shhhhh...!!! Don't tell anyone you're buying a rebuild carb!!! According to the experts, every single rebuilt carb you can buy is absolute junk, and even if it's not, the experts will blame any future problems directly on your poorly-rebuilt carb, even if it turns out to be something completely different. Don't ask me how I know. Best of luck with your engine rebuild and install, though!
I'd recommend that, if they're original or look worn, you might want to replace your motor mounts while the engine is out of the car.
VM
Users browsing this forum: Amazon [Bot] and 7 guests
