| crank definition https://slantsix.org/forum/viewtopic.php?t=17429 |
| Author: | RossKinder [ Sat May 06, 2006 1:09 am ] |
| Post subject: | crank definition |
I found this phrase about a Mopar on the internet. "the 383 ci was designed with a more agressive crankshaft " What on earth is an "agressive crankshaft?" |
| Author: | Rust collector [ Sat May 06, 2006 4:01 am ] |
I could tell you, but...I would have to erase your memory... |
| Author: | Slant Cecil [ Sat May 06, 2006 4:22 am ] |
I don't know the answer but 'agressive crankshaft' sounds better than 'submissive crankshaft'. |
| Author: | Charrlie_S [ Sat May 06, 2006 4:41 am ] |
If it is on the internet, it must be true Maybe it beats up on the bearings |
| Author: | RossKinder [ Sat May 06, 2006 9:09 am ] |
Quote: If it is on the internet, it must be true
Oh yes! As for the agressive crank,I'm not sure of the results, but I'll bet it's because the engineers forgot to run their designs by the shrink. |
| Author: | SlantSixDan [ Sat May 06, 2006 9:24 am ] |
My wild guess: Somebody meant to write "aggressive camshaft". |
| Author: | AndyZ [ Sat May 06, 2006 1:10 pm ] |
It is a crankshaft with xyy chromasome. 383 cranks make up a lot of the prisoners on death row. Just kidding. It's a beefy crank which the slant 6 has a lot in common with. |
