It is currently Thu Jun 18, 2026 5:02 am
 Post subject: Windshield installation
PostPosted: Sat Apr 22, 2006 9:51 pm
In my 64 valiant wagon, i'm about to install a windshield gasket that I bought of of ebay to replace the leaking original. Should I use adhesive on the glass to rubber side? the rubber to metal side?
Does any one have any tips or suggestions for a glass replacement virgin?
Thanks.
Delbert
PostPosted: Sat May 06, 2006 7:52 am
Car Model: A couple slant six mopars and other mopars
the service manual will aid where to apply the adheasive.. I had to redo my 70 dart because none was used by the glass guy.
PostPosted: Sat May 06, 2006 12:42 pm
Just looked at my 65 FSM and it said to apply a small bead of sealer to the windshield flange and install the weatherstrip. Once the glass is install, apply a small bead of seal between the weatherstrip and glass (would assume on the outside). Hope this helps
