| 270º erson cam - springs/lifters question https://slantsix.org/forum/viewtopic.php?t=17444 |
| Author: | argentina-slantsixer [ Sat May 06, 2006 4:41 pm ] |
| Post subject: | 270º erson cam - springs/lifters question |
hey there. just got a 270º/270º 111º centerline .465" lift erson cam for my slant. wondering if these spring specs might fit this cam: LENGTH-2.021" O.D.-1.434" I.D.-1.050" WIRE DIAMETER-0.192". Pressure: 91 lbs. at 1.650" 106 lbs. at 1.600" 183 lbs. at 1.350" 201 lbs. at 1.300" 220 lbs. at 1.250" 241 lbs. at 1.200" Coil bind at 1.110". also have a set of brand new stock lifters to match to this cam. Do I need some special break-in procedure for solid lifters? UPDATE: the seller says that those springs are good up to .500 lift cams. Set is around 50 bux on ebay. |
| Author: | Dart270 [ Sun May 07, 2006 5:58 pm ] |
If you set up the springs for 1.65 installed height, those springs will probably work for that cam. I'm not a spring expert, but from my experience, that should work, but it will be close to the edge. I think a 0.500" cam with those springs would be optimistic. Lou |
| Author: | argentina-slantsixer [ Sun May 07, 2006 7:25 pm ] |
so in other words I should look for a better option? or those would work FINE? I mean, "close to the edge" doesn't sounds very "have a very nice sleep" |
| Author: | Dart270 [ Mon May 08, 2006 6:46 am ] |
I'm just telling you what I know, which is not a definite answer, I know. I can tell you that valve springs for a 340 mopar would work well, and I'm not sure those on ebay are as strong as a 340 spring. Look up their PN and see if they are 340 springs. 340 springs can be had very cheaply, BTW. Lou |
| Author: | argentina-slantsixer [ Mon May 08, 2006 3:06 pm ] |
Quote: I'm just telling you what I know, which is not a definite answer, I know. I can tell you that valve springs for a 340 mopar would work well, and I'm not sure those on ebay are as strong as a 340 spring. Look up their PN and see if they are 340 springs. 340 springs can be had very cheaply, BTW.
Thanks again lou. Do you have any P/N for 340 springs? and where can I get those 340 springs? would stocker 340 springs be good enough for millingshop free installation? or do I have to have something machined?
Lou |
| Author: | Dart270 [ Mon May 08, 2006 5:25 pm ] |
No machining required. Look on manciniracing.com or similar for a PN. Lou |
