| paging slantsixdan https://slantsix.org/forum/viewtopic.php?t=17446 |
| Author: | moparfreak [ Sat May 06, 2006 7:10 pm ] |
| Post subject: | paging slantsixdan |
I'm probably going to be running out to a wrecking yard this week to get a windshield and rear wiper motor for my talon and was wondering what year Chevy’s I could pull a hei ignition system out of |
| Author: | Rust collector [ Sun May 07, 2006 3:33 am ] |
You can find them in most gm cars/trucks from the mid 70´s to mid 80´s, maybe a few later too. It does not have to be a chevy, every gm brand used the hei. Just look at it, and see if it has 4 connectors, not 7 (or what number the others had) |
| Author: | Charrlie_S [ Sun May 07, 2006 4:33 am ] |
If it were me, I would also get one of the HEI "E" coils. These are the ign coils that are not mounted in the distributer cap. |
| Author: | moparfreak [ Sun May 07, 2006 8:56 am ] |
ok so i should be in good shape if i can find a 83 or 84 gm truck |
| Author: | Rust collector [ Sun May 07, 2006 9:59 am ] |
Yes, or caprice, malibu, or whatever...vans... |
| Author: | SlantSixDan [ Sun May 07, 2006 10:45 am ] |
Yep, just start popping distributor caps off GM vehicles, and when you find a 4-pin module, grab it out of the distributor. The advice to get an external-mount HEI coil is good—do that. |
| Author: | GTS225 [ Sun May 07, 2006 10:48 am ] |
Hey! Don't forget to get the little plugs that go on the module, too. I get the feeling from your first post that you're looking to get the whole distributor. (Maybe I'm mistaken) If that's the case, you don't need it....just the module and plugs from inside, plus the external mount coil. Roger |
| Author: | moparfreak [ Sun May 07, 2006 9:56 pm ] |
ok thanks guys |
