It is currently Tue Nov 24, 2026 4:51 pm
 Post subject: Christmas in May!
PostPosted: Mon May 08, 2006 3:59 pm
This past weekend I scored a super six intake/carb/exhaust manifold, and a head from a '73 225 from my great uncle, and I got the kickdown linkage and a gas pedal from a junkyard. The carb has been sitting on its intake manifold out in the weather for like 20 years, and rust has frozen any moving part. I thought I'd at least try to loosen it up with penetrating oil, but I don't think it's in good enough shape to rebuild (plastic pieces broken on the acclerator shaft).
My great uncle also has a '76 truck with a 318 that he's going to take to the junkyard, and this truck last ran in the 90s, and it's been sitting with its hood closed since it's been parked. Would this carb be a good candidate for a rebuild and service on my dart with a Comp cams 252, slightly shaved head, and larger exhaust?
PostPosted: Mon May 08, 2006 4:20 pm
Yes!, keep the other one too!
PostPosted: Mon May 08, 2006 4:48 pm
I agree. Keep the Super six carb and try and rebuild it.
Try soaking it overnight in penetrating oil. If that doesn't work try putting it in a bucket of naval jelly overnight. Once you get it apart take the carburetor completely apart and soak every bit in a bucket of carb cleaner for about 12 hours.
