It is currently Tue Nov 24, 2026 11:59 pm
 Post subject: Cruise RPM?
PostPosted: Mon May 08, 2006 10:32 pm
Assuming some ideal combination of drive ratio and tire size, what would be a good cruise RPM for a normal, well tuned 225 in an A-body putting interstate miles behind?
Or I might say, what RPM is good, efficient or "comfortable" for the 225?
Since this is highway miles, I guess I would also assume we're talking about some reasonable kind of gas comsumption, that is, our speed should neither make our hair stand on end nor put us to sleep. ;)
Would carburetor have any bearing on this ideal RPM?
PostPosted: Tue May 09, 2006 2:51 am
Carb, cam, compression ratio, tranny, rear ratio, tire size, weight of the car....
I could get specific and say for me a 3500 lb Duster, 225 with about 200hp at the crank, running a small 4 barrel, 3.55 rear ratio, OD manual tranny, 9.2:1 CR, 205/70R14's really does well at about 2300 rpm @65mph on the highway grabbing about 21.5 mpg at the moment (depends on ambient temperature for this mix).
