fuel pump
https://slantsix.org/forum/viewtopic.php?t=17462
Page 1 of 1
Author:  oibrownskin [ Sun May 07, 2006 10:16 pm ]
Post subject:  fuel pump
What year fuel pumps will work with a 225 from 1966?
Where to get them? Seems yearone and Laysons only have stuff for the V8s
Caesar
Author:  CStryker [ Sun May 07, 2006 10:27 pm ]
I'd try the local autoparts store. It should still be available aftermarket. I've had good luck with both Carter and Airtex pumps, and there are many more decent aftermarket suppliers out there.
Author:  SlantSixDan [ Mon May 08, 2006 7:34 am ]
Whoah! Yeah, always try conventional sources before signing up to pay the kind of markup Year One and Layson's charge. A fuel pump for a '66 is still available at most any parts store.
Author:  Frank McMullen [ Mon May 08, 2006 12:24 pm ]
Got one from Hy-Grade (Standard Ignition Products) about four years ago... (still in the trunk)...
Also look for KEM pumps...
Good luck !
Frank McMullen
Author:  oibrownskin [ Mon May 08, 2006 3:43 pm ]
Post subject:  went to Autozone
well I went to autozone and they had everything I Needed (even a heater core) and everything was at least half (if not less) than the prices I found on Yearone and laysons. I am still going to use those guys for hard to find restoration items, but for regular stuff Autozone or Kragen (or local private owned shops).
Thanks for the heads up.
Caesar
Author:  Jeb [ Mon May 08, 2006 6:45 pm ]
Can't you swap the pump lever and make a V-8 fuel pump work on a slant?
Author:  SlantSixDan [ Mon May 08, 2006 6:50 pm ]
Fuel pressure would be way too high.
Author:  Jeb [ Mon May 08, 2006 6:59 pm ]
But it could be done if you install a regulator?
Author:  CStryker [ Mon May 08, 2006 8:17 pm ]
Lot's of things /can/ be done, but the question is, "Is it really worth the effort, when you can buy a new fuel pump for $20?"
Author:  Frank McMullen [ Tue May 09, 2006 1:55 pm ]
Caesar,
I save the "specialists" (like Layson's) for the things that I just can't find anywhere else.
For the most part, my old cars are drivers, that don't get judged, so aftermarket parts are fine with me, and I get anything I can locally from my favorite Mom'n'Pop or one of the chains...
It's amazing the amountof stuff that can be had through places like Auto-Zone, Advance Auto, Kragen, Pep Boys, etc once you convince the counter monkeys to stop looking at the computer and crack one of those big thick parts books... :wink:
Good luck !
Frank McMullen
Author:  Matt Cramer [ Wed May 10, 2006 3:43 am ]
I believe that some high performance slants do use a big block Chrysler pump with a slant six lever. Kinda pointless on a stocker, but it gives more flow volume for a built motor without the noise of an electric pump.
Author:  oibrownskin [ Sun May 14, 2006 12:03 am ]
Post subject:  weber carbs
well i bought a stock slant six fuel pump, but with my dual webers i need to get a pressure regulator. Webers run on at most 3.5psi so the regulator should help me with some problems I was having before.
thanks for the assistance.
Caesar
Author:  zedpapa [ Sun May 14, 2006 12:31 pm ]
big block pump with a slant six lever? any more info on this? i woill be putting my 4-bbl on soon and i'm haveing concerns the stock pump won't keep up. it does have 6.5 psi fuel pressure though. i haven't been able to check volume yet.
zedpapa
Author:  Dennis Weaver [ Sun May 14, 2006 1:16 pm ]
No it wouldn't - but the stock pump will do just fine with a 4-barrel for most purposes anyhow.
D/W
