| Caliper location https://slantsix.org/forum/viewtopic.php?t=17474 |
| Author: | Rick Covalt [ Mon May 08, 2006 5:53 pm ] |
| Post subject: | Caliper location |
Simple question. Are the brake calipers of the F-Body (Volare/Aspen) located on the forward side of the rotor or on the rear? Thanks |
| Author: | zedpapa [ Mon May 08, 2006 6:31 pm ] |
on my car i put them in the rear. it is possible to put them in the front if you swap the spindles side to side. with the calipers in the front you might have clearance problems with the sway bar if you have one. i don't know what effect having the calipers in the front would have on braking performance. maybe others will chime in and let us know. ' zedpapa |
| Author: | 70 Dustpan [ Mon May 08, 2006 8:09 pm ] |
Factory they are to the back. |
| Author: | Rick Covalt [ Tue May 09, 2006 3:39 am ] |
| Post subject: | Thanks |
Thanks, I was looking for the factory location, Rick |
