| Cruise RPM? https://slantsix.org/forum/viewtopic.php?t=17480 |
| Author: | RossKinder [ Mon May 08, 2006 10:32 pm ] |
| Post subject: | Cruise RPM? |
Assuming some ideal combination of drive ratio and tire size, what would be a good cruise RPM for a normal, well tuned 225 in an A-body putting interstate miles behind? Or I might say, what RPM is good, efficient or "comfortable" for the 225? Since this is highway miles, I guess I would also assume we're talking about some reasonable kind of gas comsumption, that is, our speed should neither make our hair stand on end nor put us to sleep. Would carburetor have any bearing on this ideal RPM? |
| Author: | DusterIdiot [ Tue May 09, 2006 2:51 am ] |
| Post subject: | That leaves a lot to the imagination... |
Carb, cam, compression ratio, tranny, rear ratio, tire size, weight of the car.... I could get specific and say for me a 3500 lb Duster, 225 with about 200hp at the crank, running a small 4 barrel, 3.55 rear ratio, OD manual tranny, 9.2:1 CR, 205/70R14's really does well at about 2300 rpm @65mph on the highway grabbing about 21.5 mpg at the moment (depends on ambient temperature for this mix). -D.Idiot |
