Header Leak
https://slantsix.org/forum/viewtopic.php?t=17504
Author:  Bentsix [ Wed May 10, 2006 3:28 pm ]
Post subject:  Header Leak
Just installed my Clifford shorty headers and cannot get #3 cylinder sealed properly. Tried double gasket on this tube but no luck. Any suggestions?
Author:  Matadem [ Wed May 10, 2006 6:03 pm ]
well I just went thru a nightmare (I call it headers from hell) tried just about everything with my clifford headers thin to very thick gasket.....rewelded weld rings ...grinded them flat and still leaking.. I am just drive like this for a while and put the stock exhaust back on to continue on my project....
Author:  SlantSixDan [ Wed May 10, 2006 6:46 pm ]
Author:  64ragtop [ Wed May 10, 2006 8:00 pm ]
Errr, Dan, what???
Author:  zedpapa [ Wed May 10, 2006 9:50 pm ]
i have the same problem with mine, except it on cyl. 4. i have the stock intake still and i account the leak to difference in thickness between to two manifolds. mine is still leaking and i plan to fix it when i put the clifford 4-bbl mainfold on.
zedpapa
Author:  Pierre [ Wed May 10, 2006 10:30 pm ]
My #1 ... or was it #2 was leaking. I called clifford about it and they advised to cut the flange, between the two tubes. This worked for me - guess the flange was warped a bit.
Author:  Bentsix [ Thu May 11, 2006 3:08 am ]
Post subject:  header leak
Thanks guys for your suggestions, will try cutting flange today.
Author:  SlantSixDan [ Thu May 11, 2006 7:23 am ]
Errr, Dan, what???
That was me, not sayin' a word.
Author:  Bentsix [ Thu May 11, 2006 12:53 pm ]
Cut flange between cylinders 2 & 3. For now leak seems to be sealed, only time will tell I guess. Thanks again!
