| Part Number Info for Intake/Exhaust Washers https://slantsix.org/forum/viewtopic.php?t=17536 |
| Author: | 60 Pioneer [ Fri May 12, 2006 8:30 pm ] |
| Post subject: | Part Number Info for Intake/Exhaust Washers |
This may be common knowledge for some, but I believe I have located the Mopar part numbers for the intake/exhaust manifold washers. I recieved them in the mail today and will try them out when I put my manifolds back on. Triangular Washer - p/n 3751636 (called out as "int washer") Conical Washer - p/n 3751637 (called out as "ex washer) Brass Washer - p/n 53010091 (this supercedes p/n 2121233 and is called out as "exh clamp") Some notes: The brass washer may be questionable. They are 1/4" thick, flat, and the hole looks a little bigger than the other washers. The triangular washers look pretty beefy compared to some of the older ones that I have. The dealer said that the conical washers were discontinued, but I was able to order some from WholesaleMopar.com FYI Bill |
| Author: | Charrlie_S [ Sat May 13, 2006 4:17 am ] |
How about the special nuts, that go with the brass washers? The brass washers are supposed to be that way. There is also a taper on the inside diameter, which recieves the special tapered nut. The later engines had thicker triangle washers. I think they were redisigned for beter torque retention. |
| Author: | SlantSixDan [ Sat May 13, 2006 7:37 am ] |
Quote: How about the special nuts, that go with the brass washers?
0115729 (top centre)6030210 (top front and back) |
| Author: | zooter86 [ Tue May 16, 2006 7:56 am ] |
I kno this is gonna sound ameatureish, but I got my engine w. the manifolds off & no washers or nothing. Could someone tell me how many of each washer I need and in what order they go on the motor (aka, which washer for which stud/bolt) thanks |
| Author: | 60 Pioneer [ Tue May 16, 2006 8:06 am ] |
Check out the Articles section at the Home Page. There is an article on Manifold Installation. Great info and pics. |
| Author: | zooter86 [ Tue May 16, 2006 8:08 am ] |
thank you |
