| perfromance ?'s https://slantsix.org/forum/viewtopic.php?t=17558 |
| Author: | amoshogg [ Sun May 14, 2006 10:23 am ] |
| Post subject: | perfromance ?'s |
my 225 /6 in '85 dodge trk, is quite underpowered and giving me trouble. is it possible to install a larger carb, is a 2bbl intake needed for this? also are there any other mods. that can be done, performance wise? thank you, amos |
| Author: | Matt Cramer [ Sun May 14, 2006 4:31 pm ] |
Yes, and you will need a 2-bbl manifold if you want to put on a larger carb. Best bet is a junkyard Super Six manifold. |
| Author: | amoshogg [ Sun May 14, 2006 10:30 pm ] |
which autos would have the super six manifold, and what 2bbl would be best to go with for power/fuel economy? thanks, amos |
| Author: | amoshogg [ Sun May 14, 2006 10:33 pm ] |
also, would it be possible to change the distributor from the electronic timing advance type to a distributor advance type? amos |
| Author: | amoshogg [ Sun May 14, 2006 10:37 pm ] |
edit: vacuum advance distributor from comp. controlled advance. amos |
| Author: | stuggin [ Mon May 15, 2006 10:36 pm ] |
http://www.slantsix.org/forum/viewtopic.php?t=15779 http://www.slantsix.org/articles/supersix/article.htm The first one is on the HEI conversion, the second is on the super six conversion. Cheers! Allen |
