It is currently Wed Nov 25, 2026 7:38 pm
PostPosted: Fri May 12, 2006 8:30 pm
This may be common knowledge for some, but I believe I have located the Mopar part numbers for the intake/exhaust manifold washers. I recieved them in the mail today and will try them out when I put my manifolds back on.
Triangular Washer - p/n 3751636 (called out as "int washer")
Conical Washer - p/n 3751637 (called out as "ex washer)
Brass Washer - p/n 53010091 (this supercedes p/n 2121233 and is called out as "exh clamp")
Some notes:
The brass washer may be questionable. They are 1/4" thick, flat, and the hole looks a little bigger than the other washers.
The triangular washers look pretty beefy compared to some of the older ones that I have.
The dealer said that the conical washers were discontinued, but I was able to order some from WholesaleMopar.com
FYI
Bill
Bill
'60 Dodge Dart Pioneer
Vivian
PostPosted: Sat May 13, 2006 4:17 am
How about the special nuts, that go with the brass washers?
The brass washers are supposed to be that way. There is also a taper on the inside diameter, which recieves the special tapered nut.
The later engines had thicker triangle washers. I think they were redisigned for beter torque retention.
PostPosted: Sat May 13, 2006 7:37 am
0115729 (top centre)
6030210 (top front and back)
PostPosted: Tue May 16, 2006 7:56 am
I kno this is gonna sound ameatureish, but I got my engine w. the manifolds off & no washers or nothing. Could someone tell me how many of each washer I need and in what order they go on the motor (aka, which washer for which stud/bolt) thanks
PostPosted: Tue May 16, 2006 8:06 am
Check out the Articles section at the Home Page. There is an article on Manifold Installation.
Great info and pics.
Bill
Vivian
PostPosted: Tue May 16, 2006 8:08 am
thank you
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 2 guests
