| computer problems https://slantsix.org/forum/viewtopic.php?t=17576 |
| Author: | amoshogg [ Mon May 15, 2006 12:53 pm ] |
| Post subject: | computer problems |
would the electronic controller going bad cause hesitation/low power/miss/stall, since this device controls the timing advance funtion. the carb. has been rebuilt. thanks again, amoshogg |
| Author: | mopar_nocar [ Mon May 15, 2006 12:55 pm ] |
yes. do search on this board "lean burn." you'll probably want to delete it by going to an electronic ignition kit. there are 2 on ebay for the slant right now. sb |
| Author: | KBB_of_TMC [ Tue May 16, 2006 9:40 am ] |
| Post subject: | computer |
Before replacing any of the Mopar computers, look at the grounding screws - sometimes corrosion makes for a bad ground and cause lots of problems. |
| Author: | Reed [ Tue May 16, 2006 9:44 am ] |
Vacuum leaks can also wreak havoc on a lean burn system. Be sure to check that the vacuum pod on the computer still holds a vacuum. |
