| Steering danger? https://slantsix.org/forum/viewtopic.php?t=17589 |
| Author: | RossKinder [ Tue May 16, 2006 10:35 am ] |
| Post subject: | Steering danger? |
There's a collar just below my steering coupling that actually looks like part of the coupling. There's a countersunk hole through it - not centered but apparently through part of the shaft. Shouldn't there be a pin or bolt or something in that hole? I'm guessing it must be rusted in place, but. . . |
| Author: | Patrick Devlin [ Tue May 16, 2006 2:07 pm ] |
Ross, There is a roll pin that goes through that hole. The shaft on the steering box is shaped like this: <pre> [ ] ) (O<-----roll pin | | </pre> The roll pin might be there. It's a split hollow tube, so you might just be looking right through it. Can't get my ASCII graphic to work, even with the HTML preformatting tags. |
