It is currently Wed Nov 25, 2026 10:14 pm
 Post subject: computer problems
PostPosted: Mon May 15, 2006 12:53 pm
would the electronic controller going bad cause hesitation/low power/miss/stall, since this device controls the timing advance funtion. the carb. has been rebuilt.
thanks again,
amoshogg
1985 D100 2wd RC SWB 225/6 4spd
AMOS
PostPosted: Mon May 15, 2006 12:55 pm
Car Model: 1974 W100; 72 Dart
yes.
do search on this board "lean burn." you'll probably want to delete it by going to an electronic ignition kit. there are 2 on ebay for the slant right now.
sb
PostPosted: Tue May 16, 2006 9:40 am
Before replacing any of the Mopar computers, look at the grounding screws - sometimes corrosion makes for a bad ground and cause lots of problems.
PostPosted: Tue May 16, 2006 9:44 am
Vacuum leaks can also wreak havoc on a lean burn system. Be sure to check that the vacuum pod on the computer still holds a vacuum.
Users browsing this forum: Bing [Bot] and 6 guests
