It is currently Thu Nov 26, 2026 4:02 am
 Post subject: Clifford Headers
PostPosted: Fri May 12, 2006 9:02 am
Does anyone have a 'Good' pic of the Clifford headers installed ??
I've checked the Clifford site and the pic they display isn't very good.
I'm considering them for my 62 Valiant Street Cruiser, for looks as
much as for efficiency.
PostPosted: Fri May 12, 2006 10:42 am
In my '87 D150:
PostPosted: Fri May 12, 2006 12:46 pm
Your Engine and compartment looks nice and clean (nice job) :D
The clifford site lists headers for high starter placement and low
starter placement. I assume yours is a low starter (since I haven't
looked under many of those truck hoods I'm ignorant ).
I have power brakes, will these headers clear my High starter and
also the Vacuum buster ?
PostPosted: Fri May 12, 2006 1:47 pm
Thanks! :)
My truck has both the high starter and power brakes (and a rather large diameter power brake booster I might add). The headers are Clifford's 3x2 for trucks with high-starter, and no A/C (I removed my non-functioning A/C)
Header-starter clearance with my original starter was very tight...I had to remove the starter's heat shield and very lightly dimple a header tube with a socket. In those pictures I have the newer nippondenso mini-starter installed, which gives me a mile of clearance.
No issues with the brake booster whatsoever. BUT, remember this is a truck. I likely have much more engine bay room than your Valiant.
-S/6
The "Silver Bullet"
87 Ram D150
 Post subject: Trucks have more
PostPosted: Fri May 12, 2006 2:28 pm
And lots more ground clearance!
1980 Aspen 225 super six
PostPosted: Fri May 12, 2006 5:25 pm
Anyone else have these headers on their early 'A' body ??
Looking for comments/input before I decide.
PostPosted: Fri May 12, 2006 5:50 pm
Do some deep digging on this site with the search term "Clifford" before you decide to drop the bucks for that particular item.
Then, get Dutra Duals instead.
PostPosted: Sat May 13, 2006 4:01 pm
The only new Clifford headers that will fit a '62 are their "one size fits all" shorties. They will only fit with a 198 or 225. :shock:
I have a set on my '66. They clear a high starter. :)
PostPosted: Sat May 13, 2006 7:37 pm
Any chance of seeing a pic of them ??
The long Clifford hearers as in the above pics look to work well in the
Pickup where he has a ton of room but I think would be a very tight
exit from the engine compartment of my 62 Valiant (225 eng.).
PostPosted: Sun May 14, 2006 10:44 am
Here are my Clifford shorties in my 70Valiant
 Post subject: clifford headers
PostPosted: Mon May 15, 2006 2:56 am
if you are interested in dutra Duals, there is a set on ebay up to $250
http://cgi.ebay.com/ebaymotors/Mopar-17 ... dZViewItem
also if you have a low starter, there is a set of cliffords for around $100 so far.......
73 Dart 4dr
70 duster
75 VW bug
ex-88 honda rice rocket
ex-70 cuda 383
PostPosted: Mon May 15, 2006 7:43 am
Thanks for the pic, need a little help with what I'm looking at.
It looks like you have 2 collectors, the top collector is the front 3
cylinders and a collector below the front collector taking care of
back 3 cylinders.
How tight is it getting 2 exaust pipes through next to the auto trans ?
Or do you have a 'Y' pipe and single exaust ?
@ All ........ the Dutra Duels are a good option. I really would like
to go with headers but if I can't find headers that satisfy me then
I'll go with the Dutra Duels.
PostPosted: Mon May 15, 2006 9:27 am
You are correct there are 2 collectors. I have a Y-pipe that connects to the single exhaust just behind the firewall. I did have to bend the shift linkage to be able to get it into D-2-1. I also had to reshape the trans cooler lines.
PostPosted: Tue May 16, 2006 6:29 am
Is it possible to run dual exhaust's with this header set up?
PostPosted: Tue May 16, 2006 8:21 am
yes I could easily run duals. the headers have dual outlets. I may have done that if the Y-pipe had not come with them as part of the purchase.
