| 66 and up custom dash cluster fabrication https://slantsix.org/forum/viewtopic.php?t=17654 |
| Author: | argentina-slantsixer [ Fri May 19, 2006 9:02 pm ] |
| Post subject: | 66 and up custom dash cluster fabrication |
hey guys. I'm finishing a prototype on custom dash clusters so you can add whatever gauges yo want. Planning on run 4,25" speedo and tach, and up to 8 small 2,5" gages. here's the work in progress.... when I finish the model I'll have it made in good fiberglass reinforced plastic ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
| Author: | Pierre [ Fri May 19, 2006 9:20 pm ] |
In the spirit of d-i-y, nice work! But you may kick yourself when you see this.... http://www.redlinegaugeworks.com/products.asp Hmm, your steering column hump is a bit closer to the center then the redline one is. |
| Author: | argentina-slantsixer [ Fri May 19, 2006 10:41 pm ] |
I forgot that some american models had the dash steel part cutted out to the leftmost part of the dash piece. Ours had the light switch un a piece of metal rather than inside the dash cluster. But they shure look nice! I do wanna kick me in the butt |
