| Power to manual steering(what pitman arm will work?) https://slantsix.org/forum/viewtopic.php?t=17656 |
| Author: | Brian [ Sat May 20, 2006 7:35 am ] |
| Post subject: | Power to manual steering(what pitman arm will work?) |
I am changing over my 74 Duster from power to manual steering. (race car)I need to know what year/style pitman arm will work with the smaller diameter manual box steering gear. The manual box is out of a 71 A body. Would a pitman arm from a 74 A body with factory manual steering work? The pitman arm off the 71 will not work because the steering centerlink is different. Any help or ideas will be great. Thanks, Brian |
| Author: | SlantSixDan [ Sat May 20, 2006 7:41 am ] |
I am fairly sure this is a "no go" deal. Unless I'm misremembering, both power and manual steering got the large pitman shaft for '73. But, I could easily be wrong. Looking at BigBlockDart's Steering/Suspension Parts Guide, it looks like '73-'76 A-bodies had different pitman arms for power vs. manual, so perhaps a K7075 (Moog number) will get the job done for you. |
| Author: | Brian [ Sat May 20, 2006 8:06 am ] |
Thanks Dan. I will look into the Moog K7075 and check the pitman shaft diameter to see if it will work. If not, I can find a 73 & up manual box. |
| Author: | Rob Simmons [ Sat May 20, 2006 9:43 am ] |
