| A833 2nd gear downshift grind. https://slantsix.org/forum/viewtopic.php?t=17678 |
| Author: | 64'4$peed [ Sun May 21, 2006 6:49 pm ] |
| Post subject: | A833 2nd gear downshift grind. |
When I downshift into second 50% of the time I get a little grinding action. would new gear oil help this out or will I need to replace some parts. |
| Author: | emsvitil [ Sun May 21, 2006 7:02 pm ] |
Try double-clutching. If that works, your syncho are going. The easiest solution is then do double-clutch your downshifts.... |
