It is currently Tue Oct 13, 2026 5:38 pm
PostPosted: Wed May 24, 2006 7:01 am
This is a little off topic, but my buddy has a 1997 2.5 liter Dodge Dakota that the exhaust manifold is split where it bolts to the exhaust pipe. There appears to be a 1/4" gap (split). I don't know what material it is. How can this be fixed? Welded? Brazed? J-B Weld?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Wed May 24, 2006 7:17 am
Car Model: 1974 W100; 72 Dart
not jb weld.
if its cast iron (i think it is) you can grind a 'V' into the crack and braze it using acetylene and brass. its a delicate operation, but can be done.
sb
PostPosted: Wed May 24, 2006 8:32 am
Good used exhaust manifolds for that application are cheap and plentiful in wrecking yards. You'll surely spend more time, effort and (probably) money trying to fix the cracked one, than you will just getting an acceptable replacement and installing it.
PostPosted: Wed May 24, 2006 7:49 pm
If you know a professional welder who is used to doing heavy industrial stuff, it shouldn't be hard for them to weld. A cousin of mine welded a cracked manifold for me (with nickel rod and all, I think) and it never cracked again.
'68 Dodge Dart 4dr Sedan
 Post subject: check this....
PostPosted: Thu May 25, 2006 6:22 am
http://car-part.com
best price i found was $25
sb
Users browsing this forum: Google [Bot] and 35 guests
