Fuel Cell instal - '62 Lancer
https://slantsix.org/forum/viewtopic.php?t=17725
Page 1 of 1
Author:  Terencejiminy [ Thu May 25, 2006 6:50 am ]
Post subject:  Fuel Cell instal - '62 Lancer
Refit the trunk floor of my '62 to flat. Opened up new floor 18.25" X 18.25" for the fuel cell and dropped it in. Fastened it down with Fuel Cell's screws.
ISSUE?
I have what is called an OIL CANNING effect.
Rear of Cell is too close to rear/valance/floor to move :)
but front has too much flat area?
Empty, I can pull up & down on the Cell and it moves too much on the front end. :(
Should I cross brace (1" X 1" X 1/8" angle) rail to rail :idea:
or is this of no real concern??
Thanks
Terry
Author:  slantzilla [ Fri May 26, 2006 4:22 am ]
Not exactly sure what you're getting at, but you would be better off with some support under it.
I am reading that you just cut out the trunk floor? If so, you will need a sheet metal guard under the tank to be legal anyway. The cell can not hang down unprotected. :shock:
Author:  Terencejiminy [ Fri May 26, 2006 7:46 am ]
Post subject:  Cell casing
It came with an outer shell/housing from the MFG..
I checked with Tech. Guy at Milan 2 weeks ago (brought the complete cell with me) and he said too many guys were buying the Fuel Cells without a case, Just the firm wall plactic bladder, so they put the Sheet Metal Guard rule in place.
The full case this cell has fulfills that requirement. :)
I installed the support last night. Nice and secure.
Terry
Author:  slantzilla [ Fri May 26, 2006 7:49 am ]
Cool! :D
Author:  Terencejiminy [ Fri May 26, 2006 8:00 am ]
Post subject:  One more question (This Week)
This cell has the roll over valve/vent, outlet and filler head attached. I intended in using 3/8" fuel line from here to the Blue pump then up to the front. This tank has 1/2" - #8 fittings coming out. I have no way of doing my Blue pump in 1/2".
No problem reducing it down? The outlets are #8 JIC too......
The best way to route the VENT is _____ ??
Thanks again,
Terry
