It is currently Tue Nov 24, 2026 8:33 am
PostPosted: Fri May 26, 2006 9:58 pm
The new Idler arm I got for my 64 valiant has too big a tapered shaft to fit into the old bracket hole. this hole was the cause of all the play in the front end to begin with. should I try and ream it out to accept the bigger idler arm shaft?
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sat May 27, 2006 6:59 am
Sounds like you might have an incorrect new arm.
PostPosted: Sat May 27, 2006 12:24 pm
other then the differences I mentioned it was identical to the old one. In either case. I resized the hole and bolted everything up. it seems to be alright. I'll have to wait until tuesday to get it aligned.
