It is currently Mon Oct 12, 2026 2:51 am
 Post subject: got a HEI
PostPosted: Fri May 26, 2006 6:56 pm
ok i went out to london got one out of a od chevy with the green and yellow wires off the one side now w come to the fun part i have a 85 ram which is torn to peices but had a box with two harness that plugged into it would this thing still have a ballast resistor or would this be a computerized ignition system
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Fri May 26, 2006 7:52 pm
You don't have a ballast resistor in your ignition system. You can use the stock coil and power the unit off of the (+) coil stud.
PostPosted: Sat May 27, 2006 9:40 am
i didn't think i had one but when you have had something apart for as long as his truck has been you tend to forget what you have removed
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
Users browsing this forum: Bing [Bot] and 34 guests
