| got a HEI https://slantsix.org/forum/viewtopic.php?t=17751 |
| Author: | moparfreak [ Fri May 26, 2006 6:56 pm ] |
| Post subject: | got a HEI |
ok i went out to london got one out of a od chevy with the green and yellow wires off the one side now w come to the fun part i have a 85 ram which is torn to peices but had a box with two harness that plugged into it would this thing still have a ballast resistor or would this be a computerized ignition system |
| Author: | Reed [ Fri May 26, 2006 7:52 pm ] |
You don't have a ballast resistor in your ignition system. You can use the stock coil and power the unit off of the (+) coil stud. |
| Author: | moparfreak [ Sat May 27, 2006 9:40 am ] |
i didn't think i had one but when you have had something apart for as long as his truck has been you tend to forget what you have removed |
