| Idler arm bracket resize. https://slantsix.org/forum/viewtopic.php?t=17755 |
| Author: | 64'4$peed [ Fri May 26, 2006 9:58 pm ] |
| Post subject: | Idler arm bracket resize. |
The new Idler arm I got for my 64 valiant has too big a tapered shaft to fit into the old bracket hole. this hole was the cause of all the play in the front end to begin with. should I try and ream it out to accept the bigger idler arm shaft? |
| Author: | SlantSixDan [ Sat May 27, 2006 6:59 am ] |
Sounds like you might have an incorrect new arm. |
| Author: | 64'4$peed [ Sat May 27, 2006 12:24 pm ] |
other then the differences I mentioned it was identical to the old one. In either case. I resized the hole and bolted everything up. it seems to be alright. I'll have to wait until tuesday to get it aligned. |
