| sway bar recomendations https://slantsix.org/forum/viewtopic.php?t=17768 |
| Author: | 64'4$peed [ Sat May 27, 2006 8:34 pm ] |
| Post subject: | sway bar recomendations |
I have a 64 valiant with no factory sway bar. looking to do front and rear at same time. anyone have brand recomendations? any problem installing the kits? FFI looks like there stuff is pretty well enginered for A bodies. any comments? |
| Author: | emsvitil [ Sat May 27, 2006 8:56 pm ] |
I'm using addco F/R 1 1/8" , 3/4" Just need to drill a couple of holes. See http://www.slantsix.org/forum/viewtopic ... co+valiant |
| Author: | 64'4$peed [ Sun May 28, 2006 6:37 am ] |
How does the rear bar hang? is it above or below the rear end? |
| Author: | Matt Cramer [ Sun May 28, 2006 9:11 am ] |
I have an Addco front bar. It's a real handling improvement, but I do not like the way the brackets mount to the K-member. They hang down enough that with stock torsion bars, hitting a hard bump can bottom out the brackets. Not good. |
| Author: | 64'4$peed [ Sun May 28, 2006 9:17 am ] |
From emsvitil pics. I didn't like the way the brackets lined up under the K frame. two squares at different angles you could always trim off the excess. The firm feel brackets I thought looked like a cleaner install with better ground clearance. |
| Author: | emsvitil [ Sun May 28, 2006 3:11 pm ] |
Quote: I have an Addco front bar. It's a real handling improvement, but I do not like the way the brackets mount to the K-member. They hang down enough that with stock torsion bars, hitting a hard bump can bottom out the brackets. Not good.
I haven't had a problem with hitting the brackets. With a little grinding I could even get them fully out of the way. I may have managed to mount them higher on the K-member than you did.......... |
| Author: | emsvitil [ Sun May 28, 2006 3:14 pm ] |
I will agree that firm feel has a better mounting system in front (and probably rear)......... But for the cost of 1 bar at firm feel you can get the pair of addco bars............. |
