| oil pan gasket.........Fun.... https://slantsix.org/forum/viewtopic.php?t=17773 |
| Author: | kmccann09 [ Sun May 28, 2006 9:00 am ] |
| Post subject: | oil pan gasket.........Fun.... |
Great day to all putting back together the motor, and wow.........the pan gasket was something else, at the time i've got it all gasket sealed up and ready for an easy install, and then wait.........the rubber ggromsaren't staying in the holes Ended up pulling the groms through with a pair of needle nose plpliers.anybody else have a good time with this>>>>>>>>? |
| Author: | CStryker [ Sun May 28, 2006 10:04 am ] |
Yeah, I just ended up pulling the little fingers through with a pair of pliars as well. The ends didnt make me fell all that confident either, but it all seems to have sealed up pretty well and theres no leaks. |
| Author: | GTS225 [ Sun May 28, 2006 10:14 am ] |
Yep!.....that's what you gotta do to get it to seat, and that's why the little tips are molded that way. A little sealer or WD-40 helps them to slip through, also. Roger |
| Author: | Mel Ott [ Sun May 28, 2006 10:15 am ] |
Quote: Yeah, I just ended up pulling the little fingers through with a pair of pliars as well. The ends didnt make me fell all that confident either, but it all seems to have sealed up pretty well and theres no leaks.
Yup.. pulling the tits through with pliers then use some Crazy/Superglue (between the 'Clean' pan and rubber gasket) to hold it in place. Works great ..... |
