It is currently Sun Oct 11, 2026 6:39 pm
 Post subject: Blow out
PostPosted: Mon May 29, 2006 8:31 pm
The gasket between my exhasut manifold and the head pipe burned out during a pass down the dragstrip Sunday. I think the manifold is warped at the sealing surface. Can I stack two gaskets together to eliminate this problem. Inside the car it sounds like Charlie's Barracuda. Do they make a dead soft gasket that will conform to irregular ssurfaces? Or will high temp RTV work.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Mon May 29, 2006 8:37 pm
More commonly it's the headpipe flange that warps. Pairing gaskets will appear to have fixed the problem...for a couple-few weeks, then it'll come back.
PostPosted: Mon May 29, 2006 8:42 pm
So, what can I do? Will the leak get worse as time goes on? I can feel it at idle but it is only audible at full throttle.
82 D150-225/727
PostPosted: Mon May 29, 2006 8:44 pm
A header gasket with a soft metal ring may work.
I used to regularly blow out a plain gasket on a flanged muffler connection until I replaced it with a header gasket, hasn't blown out since. (thinking about 10 years so far)
PostPosted: Mon May 29, 2006 8:47 pm
What kind of collector gasket did you use? Pics or part # would be appreciated.
82 D150-225/727
PostPosted: Mon May 29, 2006 8:53 pm
That'd probably help, but...who makes such gaskets in the 2-bolt configuration needed for the stock exhaust manifold's outlet? Nobody I know of...
 Post subject: these guys
PostPosted: Mon May 29, 2006 9:24 pm
Car Model: 1974 W100; 72 Dart
if i read the catalog correctly, these guys have what you're looking for:
http://www.remflex.com
its at the bottom of the catalog page.
sb
PostPosted: Mon May 29, 2006 9:43 pm
It was a 3-holer with 2.5" id. Had an unwelded exhaust flange and went to auto parts store to figure out what would fit deals.............
Didn't realize the stock exhaust is a 2-holer.......... :(
 Post subject: Re: these guys
PostPosted: Tue May 30, 2006 7:54 am
Looks like you might be right; their P/N RF6006 is described as 2¼" centre pipe hole, 2 bolt holes placed 3½" centre-to-centre. I haven't measured the centre-to-centre on a SL6 exhaust manifold, but that sounds about right. Looks as if they also have an intake-and-exhaust manifold gasket # RF6008.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Plymouth_Ruster and 38 guests
