It is currently Sun Nov 15, 2026 12:04 pm
 Post subject: Kickdown ratio : 1?
PostPosted: Sat May 27, 2006 6:39 pm
Not sure my other post got much readings so i post it as a subject in case someone knows but didn't read...
So, i've got a small question : does anyone know what the "kickdown ratio" is? I read somewhere it was 1. That means the same distance is covered at the same moment by the throttle lever and kickdown lever right?
Thanks for your help, i'm planning to make a kickdown cable but i wanna be sure i have to attach it at the same place (or opposed by the diameter) as the throttle cable.
Marc
