| GM EFI on 6, will it work on a 4or 8? https://slantsix.org/forum/viewtopic.php?t=17792 |
| Author: | TheEquineFencer [ Mon May 29, 2006 7:08 pm ] |
| Post subject: | GM EFI on 6, will it work on a 4or 8? |
I Just finished reading the EFI article and it really has me thinking. It's great to see someone do an in depth how to on the subject. I am wondering if a 4 cyl and a V-8 batch fire system works the same. What would it take to install the same type system on a 4 or 8 product? Would I need to get it from a 4 or 8 or use the same and just add injectors piggy backed off the same batch? Are the GM injector high or low impenance Inj? Can higher flow from another engine be added in place of the OEM?:?: [/b] |
| Author: | moparfreak [ Tue May 30, 2006 3:09 am ] |
most chrysler 4's and 8's were set up wih fuel injection after they brought out the 3.9L V6 unless your working with an engine that was discontinued before the late 80's early 90's |
