| those cool tubular upper control arms.... https://slantsix.org/forum/viewtopic.php?t=17798 |
| Author: | green convertible [ Tue May 30, 2006 12:59 am ] |
| Post subject: | those cool tubular upper control arms.... |
who sells those, and how much do they cost, and do they come with ball joints? i think mine are shot! thanks I guess you can tell, i have been away for a while, but we just slapped about 5k miles on the convertible down and then up the pacific coast on teh 101 so the things that I forgot about when I was over seas are starting to bug me again, and man does that car wonder, worse than my posts!!!!! Richard |
| Author: | 64ragtop [ Tue May 30, 2006 4:53 am ] |
| Post subject: | Re: those cool tubular upper control arms.... |
Quote: who sells those, and how much do they cost, and do they come with ball joints? i think mine are shot! Richard
https://www.reillymotorsports.com/store ... hp?cat=250There are others as well, but this one was bookmarked! |
| Author: | Walter Lee Jackson [ Tue May 30, 2006 6:16 pm ] |
Firm Feel has them: http://www.firmfeel.com/tubuca_a.htm --Walt Jackson |
| Author: | tophat [ Wed May 31, 2006 6:04 am ] |
if I read both sites correctly the RMS uca wses a factory bj the firm feel dont say what it uses, but from what I could see on the pic it did not look like a factory screw in type anyone know for sure? I may need these too since I am having a hard time finding a 73-76 factory uca Phillip |
| Author: | andyf [ Wed May 31, 2006 9:34 am ] |
Firm Feel uses a standard screw in ball joint. I have the FFI control arms on my '65 Coronet.
| Author: | 74.swinger [ Sat Jun 03, 2006 12:44 pm ] |
Quote: Quote: who sells those, and how much do they cost, and do they come with ball joints? i think mine are shot! Richard
https://www.reillymotorsports.com/store ... hp?cat=250There are others as well, but this one was bookmarked! ________ Ford Pampa Specifications ________ Entourage Advice |
| Author: | Sam Powell [ Mon Jun 05, 2006 7:04 pm ] |
I got mine from bigblockdart.com and they improve the handling considerably. You can put in more caster. On my set up, even with "problem solver" bushings, i could not get over 1.5 degrees of caster, and the on center feel was weak. Now witht he tubular upper control arms I have my caster set up now at 8 degrees, and it feels like a modern car in that the wheel snaps back to center when you release it. I may dial that back a bit, but it is fun to drive that way. I suspect the high caster number may take away a little on gas mileage as there is more rolling resistance going through a curve with the higher caster number. I also have the camber set at -.5 degrees. I have not seen excessive tire wear yet. I am told that radial tires handle that camber setting better than the old bias ply tires do/did, as the stiffer tread stays flat to the ground better. |
| Author: | Orange72 [ Mon Jun 12, 2006 2:33 am ] |
I bought a set from this guy a while back; they aren't on the car yet, but they seem to be well-made... http://cgi.ebay.com/ebaymotors/Mopar-A- ... dZViewItem |
| Author: | Hyper'72Valiant [ Tue Jun 13, 2006 12:20 am ] |
I just last week got those tubular uca's. They do look well made. Nice guy. Came with some tips and instructions as well. I, as well, don't have them on yet. Cory |
