| how about this?.. https://slantsix.org/forum/viewtopic.php?t=17815 |
| Author: | Draco_Scaline [ Wed May 31, 2006 5:33 am ] |
| Post subject: | how about this?.. |
http://www.moparmusclemagazine.com/feat ... les/45318/ a hemi six? O.o is there any way to convert a 225 into this set up? or find one in the states? |
| Author: | Matt Cramer [ Wed May 31, 2006 8:15 am ] |
The engine is totally unrelated to the slant. And it was never installed in LHD cars, making swapping one in somewhat tricky. |
| Author: | DionR [ Wed May 31, 2006 8:26 am ] |
Quote: The engine is totally unrelated to the slant.
Intake and exhaust look real similar to a slant, wouldn't surprise me if the top end is modelled after a one (they used /6's until '69 downunder), but on an upright block. The bore and stroke is completely different, and valve sizes were quite large (1.96 and 1.60), at least compared to a slant. I know they aren't a true hemi, but don't have a clue what the combustion chambers looked like.And it was never installed in LHD cars, making swapping one in somewhat tricky. I wonder if similar cam, intake and exhaust on a /6 would give similar results. Can't disagree, though. I'm sure parts wouldn't swap and I wouldn't want to try and swap one into a LHD car. Check out this thread for a link to a Australian inline six with a turbo. http://www.slantsix.org/forum/viewtopic.php?t=17497 Not really related to the question, but the pictures are interesting to look at in comparison to a slant. |
| Author: | SlantSixDan [ Wed May 31, 2006 8:32 am ] |
Quote: Intake and exhaust look real similar to a slant.
Conceptually similar (non-crossflow head) but that's it. No interchangeability there.Quote: Wouldn't surprise me if the top end is modelled after a slant
Well, that sort of depends on what you mean by "modelled after". The basic concept of the D-engine ("Hemi-6") was designed in the US, but then abandoned and given over to Chrysler Australia, where the bulk of the design, engineering and development work was done.Quote: I know they aren't a true hemi, but don't have a clue what the combustion chambers looked like.
There've been pictures posted in other threads, see e.g. HereQuote: I wonder if similar cam, intake and exhaust on a /6 would give similar results.
Not really...oversquare vs. undersquare, different combustion chamber, etc.Quote: I wouldn't want to try and swap one into a LHD car.
Can't imagine why not. It's been done with little to no difficulty, AFAIK, there's nothing to get in the way of the LH-side steering box.
| Author: | SlantSixDan [ Wed May 31, 2006 8:34 am ] |
Quote: And it was never installed in LHD cars, making swapping one in somewhat tricky.
I've seen a couple Hemi-6 swaps into LHD cars, and never heard of or seen any tricky or problematic areas...what've you seen/heard?
| Author: | DionR [ Wed May 31, 2006 8:34 am ] |
Sorry about that Dan, I went back and edited after you quoted. |
| Author: | DionR [ Wed May 31, 2006 8:43 am ] |
Quote: Well, that sort of depends on what you mean by "modelled after". The basic concept of the D-engine ("Hemi-6") was designed in the US, but then abandoned and given over to Chrysler Australia, where the bulk of the design, engineering and development work was done.
Intake and exhaust still use the triangle washer setup that allows expansion and contraction. Bolt locations are different, though.By "modelled after", I mean that they show enough similarities to lead me to believe that one is a continuation (or evolution) of the other. Wouldn't surprise me if valve centerlines and angles are different, maybe even port sizes, but the rest makes me think slant 6. Just an observation. |
| Author: | Draco_Scaline [ Wed May 31, 2006 8:55 am ] |
so are we saying that one can not 'hemi out' a /6 with a set up like this? or there is really no benefit to it? |
| Author: | SlantSixDan [ Wed May 31, 2006 9:15 am ] |
Quote: so are we saying that one can not 'hemi out' a /6 with a set up like this?
Correct. You cannot bolt a Hemi-6 head to the slant-6.
| Author: | DionR [ Wed May 31, 2006 9:38 am ] |
Hmmmm..... What if someone were to offer to cast new aluminum heads for the slant 6? Maybe they could model them after the Hemi-6 from Oz. |
| Author: | SlantSixDan [ Wed May 31, 2006 10:00 am ] |
Round and round and round we gooooo.... |
| Author: | Matt Cramer [ Wed May 31, 2006 11:09 am ] |
Quote: Quote: And it was never installed in LHD cars, making swapping one in somewhat tricky.
I've seen a couple Hemi-6 swaps into LHD cars, and never heard of or seen any tricky or problematic areas...what've you seen/heard? |
| Author: | DionR [ Wed May 31, 2006 11:46 am ] |
Quote: Round and round and round we gooooo....
Sorry, I know I made a bad joke. |
| Author: | VE Safari [ Thu Jun 01, 2006 12:13 am ] |
Aluminium hemi heads are available here in Australia. They are pretty expensive, soemthing like AU$2000. A hemi 6 recently passed the 400HP mark as well. There is a wealth of info available here: MoparMarket Hemi6 forum |
