| Crazy induction? https://slantsix.org/forum/viewtopic.php?t=17905 |
| Author: | RossKinder [ Mon Jun 05, 2006 1:14 pm ] |
| Post subject: | Crazy induction? |
I've seen some really nice looking 4 bbl manifolds out there. Good looking runner configurations. I wonder if anyone ever tried putting a 2 bbl on one of those - just for kicks (I mean research). |
| Author: | Matt Cramer [ Mon Jun 05, 2006 4:10 pm ] |
Quite doable on all the Clifford ones as they offer a two barrel mount as an option. I used to have an Offy manifold and it looked like you could remove and replace its carb plate to convert it to a two barrel manifold too. |
| Author: | AnotherSix [ Tue Jun 06, 2006 6:41 pm ] |
I have an Offy that I plan to adapt to a two barrel. Really I just need to cut the clover leaf center out and make an adapter plate. I measured the distance from the flange surface of the intake (where it attaches to the head) and the carb studs and bores on a stock super six intake. It will line up just fine. I am planning a combination that seems to be in between two and four barrel and this way I can swap up to four really easy if I decide to. Besides I wanted a good aluminum intake that bolts up to the exhaust. |
| Author: | slantzilla [ Tue Jun 06, 2006 7:40 pm ] |
It has been done many times. Somewhere in all my junk I have the 2bbl adapter plate for a Clifford intake just for the 2300 Holley. |
| Author: | RossKinder [ Tue Jun 06, 2006 9:42 pm ] |
Quote: It has been done many times. Somewhere in all my junk I have the 2bbl adapter plate for a Clifford intake just for the 2300 Holley.
My thought was that some of the 4 bbl manifolds look laid out a lot better. (More equal runners.) Are they?Thanks. |
