It is currently Mon Nov 23, 2026 1:28 pm
PostPosted: Tue Sep 12, 2006 1:50 pm
First of, I noticed this big hole above my timing chain today. It has threads in it. Is it supposed to have a plug in it?
Second, I tried to remove the galley plug behind the cam gear and it won't budge. I am afraid that I am going to break the allen wrench off in it. Are these things supposed to be be this tight?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue Sep 12, 2006 2:07 pm
Jeb,
I have the same situation. I have my block stripped down and was starting the pull the freeze plug. I have one of these threaded plugs in the front AND the back of the block. I ruined the tip of my allen wrench trying to break the front one loose.
I thought about getting a hardened allen bit with a socket and see if I can't beak it free with a breaker bar. Just don't want to ruin the plug and have to drill it out.
Bill
Bill
'60 Dodge Dart Pioneer
Vivian
PostPosted: Tue Sep 12, 2006 2:13 pm
IIRC, the hole you are pointing at is a drain hole.
To try and break the plugs loose, put a piece of allen wrench in them and whack it with a hammer a couple times. That may break them loose so you can turn them out. :shock:
PostPosted: Tue Sep 12, 2006 4:34 pm
Hey Dennis I wacked it a few times with a hammer and it came right out.
82 D150-225/727
PostPosted: Tue Sep 12, 2006 4:39 pm
Jeb, As slantzilla has said, The hole you are pointing to in that posted pic is a drain hole to Drain the front lifter Galley and Lube the Timing Chain.
It might have threads in it, but there should be no plug in it.
Users browsing this forum: Google [Bot] and 7 guests
