side updraft carb?
https://slantsix.org/forum/viewtopic.php?t=17949
Page 1 of 1
Author:  Andy's GT [ Wed Jun 07, 2006 3:02 pm ]
Post subject:  side updraft carb?
i read somewhere, here most likely, that the clark cortez motorhomes had sideupdraft carbs, i dont know what that is, i am really curious, is the whole manifold different? whats the hp/torque on those? any info appreciated!
Author:  SlantSixDan [ Wed Jun 07, 2006 3:09 pm ]
The Clark Cortez used a single horizontal (or "sidedraught" -- not "side updraught", no such thing) Carter YH carburetor mounted on a special intake manifold that had the regular top mounting flange blocked off with a plate. The YH carb was mounted to a mounting flange on the outboard vertical surface of the intake manifold (where the EGR valve is on late-model intakes, via a different flange). Horsepower on that 225 engine in the Cortez was 127, compared to the standard 225's 145.
