It is currently Tue Oct 28, 2025 10:47 pm
PostPosted: Wed Jun 07, 2006 6:45 pm
PostPosted: Wed Jun 07, 2006 7:16 pm
I would look at ignition issues. I know it sounds impossible, but a slant will run just the way you described if you have the firing order completely backwards. That is, if you start at number one, and count the wrong way, it WILL run, but have the missing, and backfire as you describe. Ask me how I know. :oops:
PostPosted: Wed Jun 07, 2006 7:51 pm
Also check the carb and make sure it's not dumping raw gas into the engine. It sounds a lot like you're flooding the engine.
PostPosted: Wed Jun 07, 2006 8:21 pm
Timing off?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Wed Jun 07, 2006 8:39 pm
RV grind cam with valve lift of .415 intake and .424 exhaust, running duration of 244 intake and 248 exhaust, duration at .050
Sounds not so much like an "RV-grind" cam to me. What caused your cam grinder to send you this particular grind?
This is the engine with the hydraulic lifter cam in an engine with solid lifters, and cam grinder said to tighten valves to 10 and 12…I just didn’t want to do so before breaking in cam.
Guess we weren't as convincing when we said "No, wrong, don't do it, you might could make it run OK but it'll wear fast, go get the right camshaft for your engine" as your (s)cam-grinder was when he said "Aw, don't listen to those guys, just crank down your valve adjustment and the hydraulic cam will work fine!". What happened to your sentiments of this past January, when you wrote:
Thanks for advice and sympathy re. my discovery of the hydro cam instead of solid lifter cam. I absolutely agree with doing it all over since I always try to do it right, and darn it, the engine is out...it will never be easier to do again. SO using the information (lessons) I got in response, I again called the cam grinder. I mentioned that I regretted having to revisit the issue, but had been thinking that in light of a /6 resurgence (as in Mopar Muscle) plusthe existence of a large community of knowledgeable consumers I felth honor bound to inform, I wanted to see what could be done in a even up swap, at least. They "had been thinking about it" and I get to trade back for the right cam and get a cash "labor adjustment".This would not have happened without your support
I wasn’t figuring on a lope with a such mild cam
Still doesn't sound like "such" a mild cam. That's also a very large carburetor you've got (I would say unnecessarily large).
Vacuum at idle speed of 1800 rpm was 12.5 inches
Low.
I know Dan recommends 5 degrees BTDC timing
Sometimes I do...sometimes other settings are more appropriate, depending on the setup.
PostPosted: Wed Jun 07, 2006 8:42 pm
6 Pack Dart
What does your cam card indicate for valve lash, o.010 & o.020 are the correct gap for stock cam. You may have the valves set way off from what the cam was designed to run them at.
Just a sugestion.
PostPosted: Wed Jun 07, 2006 9:21 pm
That's just it...he's running a hydraulic cam in his solid-lifter engine, so there's no such a thing as the lash setting it's "supposed to run at". His cam grinder didn't follow directions and sent him the wrong cam.
PostPosted: Wed Jun 07, 2006 10:27 pm
Confirm the timing setting, at what RPM was it checked? Did you try turning the distributor while the engine was running to see if it ran better at a different position? (Time it by ear)
Tripe check the firing order, 1-5-3-6-2-4
How do the valves sound, do they tick a lot or are they real quiet?
Was the cam degreed-in?
Is the carb new? What do you know about it?
Is the engine cranking over freely?
Getting spark and fuel?
Fuel, compression and spark at the right moment...and it will run.
PostPosted: Thu Jun 08, 2006 2:59 am
I'd check if you ain't getting 2 cyls 180 off (like 2-5 or 3-4 maybe all of them, slant will run with some or all cyls 180º off producing the effect you describe more or less)
as far as for hidro cam on solid engine, I'm running one. Valve lash is really tight (almost zero lash) I'm using .20 mm on intake and .35mm on ex (that being 0.008in and .012ex) and runs fine. Other valve lashes rendered poor vacuum and power results and bad overall feeling.
doc's advice is good, check for excessive loud or soft valvetrain noise (excessive noise indicating over advance and quietude the exact opposite) and double check your distributer's position (maybe you're way off at the dist... or maybe the cam is misdegreed in) cranking speed would indicate off-time values just like valve noise: too much speed and "happpy free spining" and your timing is retarded, to hard, and often "counterkicking" and you're way advanced.
I've ran this hidro profile cam (280ºin290ºex stock lift stock everything else (welded and reshaped cam) on my solid lifter engine for 20k mile. I gotta tell you, I made it work but you have to be up that valves lash behind all the time. I'm going to a 270º erson cam now. I'm trading off a good lobe profile and less duration with higer lift for the cam I have now, expecting to get more useable low end spunk.
Juan Ignacio Caino
PostPosted: Thu Jun 08, 2006 8:33 am
The idle mixture screws wont have any effect until your idle is lower. ..
Once you get your misfire sorted out and can get it to idle at 900-1000 rpm , try setting the lash while running to get best vacumn. Lower idle to 750-800 and try for best vacumn with lash settings and timing.
Once you can get good vacumn at a smooth idle try setting timing at 3000 rpm for best vacumn and smooth running......if the advance is the same you are in the park. If you have to change the timing you need to work on your advance curve.
Remember ....a fresh rebuild will change almost daily as it breaks in.
PostPosted: Thu Jun 08, 2006 10:51 am
... Remember ....a fresh rebuild will change almost daily as it breaks in.
all excelent suggestions but amen to that last one! :D
Juan Ignacio Caino
PostPosted: Thu Jun 08, 2006 2:47 pm
sounds like a bad vacuum leak to me and possibly multiple problems.
________
Tl1000s
________
T100
PostPosted: Thu Jun 08, 2006 5:07 pm
Even the most brilliant engine builders can get messed up with the initial timering of a freshly rebuilt engine. Everything changes, the distributor is hard to see on this car, it turns backwards from some engines, and to make make matters worse, with a slant it is really possible to have the harmonic balancer spin on the core and leave it registered wrong. Plus if you have a mismatched timing chain cover and harmonic balancer, you got more problems. As AC became more popular, Mopar moved the timing mark from the left side fo the engine to the right. These parts will all bolt together with no problem, but not be mated correctly if you have a balancer from an early year, and a cover from a later one. You must find top dead center reliably, mark your balancer to your timing cover, and then make sure you are clear about what position is correct for advanced relative to number one. If you are in doubt, drill a big hole in the top of a spare distributor cap, and put that on while you rotate the engine by hand. Remember that 1 degree at the distributor is 2 at the crank. It is really easy to be way off.
PostPosted: Thu Jun 08, 2006 8:04 pm
I had a problem with timing when I painted what I thought was the one and only timing mark on the balancer and pulled out the distributer, well, I found there was really three ( I forgot what I did exactly) but the timing was way off anyway and the same thing happened to me. I had to turn the distributer to calm it down thats when I noticed the error of my ways. So I pulled the distributer again and lined it up proper with the real timing mark. In haste it was real easy for me to screw up things fast but now I know.
