| what light on the dashboard is this for this 75'? https://slantsix.org/forum/viewtopic.php?t=17960 |
| Author: | Eatkinson [ Thu Jun 08, 2006 1:01 pm ] |
| Post subject: | what light on the dashboard is this for this 75'? |
I have a 74 Swinger. it's beautiful. It's dashboard has a round 'fasten seat belt' warning light, located beneath the fuel gauge. I have noticed that on some 74 and 75 Custom/SE models, there's another...something located next to this light, beneath the temp gauge. Whatever it is, my 74 Swinger doesn't have it. Here's a link to a photo of one. What is this? another warning light? or something else? |
| Author: | 74DartSwinger [ Thu Jun 08, 2006 4:12 pm ] |
That would be the EGR warning light. Look under the hood. There is a rubber covered thingy that connects the lower part of the speedo cable to a shorter upper part. I believe it is some sort of mileage counter that warns that it is time to check the egr. I just unplugged the wires on mine. My egr is working fine and that little dash light is really bright red and kind of annoying. |
| Author: | Eatkinson [ Fri Jun 09, 2006 12:37 pm ] |
| Post subject: | thanks! |
hmm. interesting, all these archaic 70's safety features! |
| Author: | KBB_of_TMC [ Mon Jun 12, 2006 11:23 am ] |
| Post subject: | EGR light |
74DartSwinger is absolutely right; the EGR light was run by a little clockwork mechanism off the speedometer cable that didn't "know" anything about the EGR, it was just a reminder to check it every so many thousand miles. Normally, one could use an allen wrench to reset the clockwork for another round. I combined the EGR light with the Fuel Pacer control to make a Yee-Haw light that congradulates the driver for stomping on it. The hard part was the legend - a bulb overheated it, so I made a bright LED replacement for the bulb. |
| Author: | Eatkinson [ Mon Jun 12, 2006 1:48 pm ] |
| Post subject: | interesting |
you guys seem to know all about these lights. what about the light next to it; the fasten seat belt light? does the light work on your car? do you have that Seatbelt/interlock safety function working? or does the light just not work? |
| Author: | DusterIdiot [ Tue Jun 13, 2006 9:12 am ] |
| Post subject: | Yep... |
Quote: the fasten seat belt light
Yep, and if in working order has an accompanying buzzer that goes on for 5 seconds until you belt in, or it just goes out via timer... Goes with the interlock system (sensor in the seat meshing) on pre-75 cars...after 75 it may have a system tied to the seatbelt that just cuts out the buzzer... -D.Idiot |
| Author: | Eatkinson [ Tue Jun 13, 2006 1:18 pm ] |
| Post subject: | i.e., |
so if the interlock system has been disabled, the light on the dash won't work? i have the buzzer working - it's just the key in the ignition, when the door's opened. when the key's in the ignition and the door's shut, it doesn't buzz at all... |
| Author: | 74DartSwinger [ Tue Jun 13, 2006 10:24 pm ] |
I am getting ready to install some of those cool hard back buckets from a 67 cuda in place of the bench seat. I am pretty sure that the buzzer is just straight connected through the belts not a seat sensor. But I guess I will find out the truth to that . I'll let you know if I remember! |
