It is currently Tue Nov 24, 2026 1:21 pm
PostPosted: Sat Jun 10, 2006 11:42 pm
This is gonna sound really dumb as I have rebuilt many engines but... where is the timing indicator on a slant 6?
i have looked everywhere for it but it is either not there anymore or its hiding on me.
I do have a dwell meter... will this help me set my timing?
Thanks in advance for any responses.
Gordon
1983 Dodge D150 Truck
225 slant 6
Black in color
Plans:
Rebuild engine
Turbo charge it
Paint it Canary Yellow
oh and get signal lights (broken column)
PostPosted: Sun Jun 11, 2006 6:53 am
Car Model: '23 T-bucket
You mean the pointer, or the balancer indication?
Roger
PostPosted: Sun Jun 11, 2006 9:50 am
The pointer is what I believe is missing.
The mark on the harmonic balancer is easy to find
Gordon
225 slant 6
Black in color
Plans:
Rebuild engine
Turbo charge it
PostPosted: Sun Jun 11, 2006 1:06 pm
Should be on the passenger side of the timing cover; Even if it's missing, I imagine the stud that it bolts to should still be there. I can grab pics if you need.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Sun Jun 11, 2006 2:36 pm
If you could post a pic that would be awesome.
So far all of you are very helpful and polite unlike some childish car forums.
225 slant 6
Black in color
Plans:
Rebuild engine
Turbo charge it
PostPosted: Sun Jun 11, 2006 3:20 pm
The dwell meter, as I understand it, is for setting the points gap, which you don´t have (points) on an 83.
Well, if it has not been fitted with an early ignition system, that is.
PostPosted: Sun Jun 11, 2006 4:37 pm
I think i have the timing about right just by ear but I'm still having a bit of lag in acceleration under half throttle.
Do you suppose i need a new carb or just rebuild it?
What carbs will fit this engine anyways? Any 1bbl?
225 slant 6
Black in color
Plans:
Rebuild engine
Turbo charge it
Users browsing this forum: DuckDuckGo [Bot] and 5 guests
