It is currently Sun Nov 15, 2026 6:55 am
 Post subject: Hole in a 7 1/4 housing
PostPosted: Sun Jun 11, 2006 11:25 am
This afternoon, i noticed a hole in the left part of my 7 1/4" rearend. It really looks like factory. Since the "T" for the brakelines is closeby and also has a hole in it i'm wondering : would that be a threaded hole to screw the T in position? I managed to screw in a bolt but it almost felt like i was making the threads myself so... Hope I didn't do anything wrong...
Thanks for your answers.
Marc
PostPosted: Sun Jun 11, 2006 11:49 am
Without seeing a picture, I guess you are probably seeing the vent hole. This is meant to have a little vent cap in it to keep out splashed water, but allow hot air to escape.
PostPosted: Sun Jun 11, 2006 12:41 pm
So i'm missing something right?
PostPosted: Sun Jun 11, 2006 1:18 pm
Yeah; there should be a little hose barb that screws in the hole and serves to both attach the brake T and vent the rear. The threads will be some flavor of NPT (not sure, but I'd guess around 5/16).
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Sun Jun 11, 2006 2:48 pm
Thanks!
Do I really risk something by letting it breathe in the air? Or by blocking it? (i gotta fix that T!)
PostPosted: Sun Jun 11, 2006 3:25 pm
The air is ok, but keep water and dust out of it!
PostPosted: Sun Jun 11, 2006 4:04 pm
Some time ago I know those vent mechanisms were availible for a few bucks from the dealer for the 8 3/4", not sure if its the same for the 7 1/4" but worth a shot calling your dealer. Sorry, don't have parts manaual handy at the moment or else I'd get you the #.
PostPosted: Sun Jun 11, 2006 5:23 pm
the little check valve is available for newer cars. they usually go in the end of a hose though. Screw in a hose barb and put a hose on with a check valve on the end. usually tied off to crossmember.
This style is a must on anything that goes offroad.
________
R65
________
Ford falcon xr6 turbo picture
PostPosted: Sun Jun 11, 2006 7:09 pm
I believe those are all A universal Part# at the dealer - I got one for my 3/4 Ton 77 Truck from the dealer - Looked Great and Functioned great - My truck has a dana 60 Rear.
