Nitrous or Propane
https://slantsix.org/forum/viewtopic.php?t=18003
Page 1 of 1
Author:  slantdog225 [ Sun Jun 11, 2006 1:11 pm ]
Post subject:  Nitrous or Propane
i wanted to know if anyone Knows of a propane kit or a nitrous kit that u can buy for a 225 / 6 i have herd that propane was a cheap version of nos
Author:  Charrlie_S [ Sun Jun 11, 2006 2:23 pm ]
You need to do a little research/study, before considering either one. Propane is a fuel, Nitrous is an oxidiser. Gasoline is a fuel, air is an oxidiser. Two completely different animals.
Author:  Rust collector [ Sun Jun 11, 2006 2:35 pm ]
Ummm, I think you are thinking about diesel engines, they use propane as a kinda nitrous-ish setup.
Author:  Joshie225 [ Sun Jun 11, 2006 4:16 pm ]
If you want to be brave you can use propane as the extra fuel for use with nitrous, but I wouldn't recommend it for a first timer. Gasoline and alcohol (ethanol or methanol, but I prefer ethanol as it's less corrosive) are much easier to use with nitrous as all the hard work has been done by the kit manufacturers. Propane only works on diesels as they have excess air with which to burn the propane.
Author:  slantdog225 [ Mon Jun 12, 2006 12:19 pm ]
i know that propane is for diesels im not stupid. but some guy that i work with said that it was just a cheap verson of nos sounds like he is the dumb one i just was not shoer of it cuz i have never herd of propane subbing for nos dose anyone know of a nos kit for a /6
Author:  Joshie225 [ Mon Jun 12, 2006 4:09 pm ]
Ok, bud. You want to be called stupid fine. You're stupid. Are you shoer you herd me? Keep taking this attitude and see how far it gets you.
Author:  slantdog225 [ Mon Jun 12, 2006 7:16 pm ]
what attitude? You must of took it the wrong way i was just saying that i new propane was for diesels i'm sorry if you took it that way but i did not mean it that way.
Author:  imnoisydart [ Mon Jun 12, 2006 9:26 pm ]
Well to get this back on course (?)
almost all nitrous kits can be used on a slant 6.
Easiest way is to use a 4 bl. intake manifold and
a plate or top shot system thru the carb.
But of course propane is a whole different subject.
Author:  slantzilla [ Tue Jun 13, 2006 4:06 am ]
I run a Top Gun plate system, but I feel that an NOS or Nitrous Express would be a better choice. Whatever you do, do not skimp on fuel supply to it. :shock:
Author:  Ron Parker [ Tue Jun 13, 2006 6:44 pm ]
Yall better git along or i will take my belt off. Ron Parker
It Aint Over Until I Win
Author:  AndyZ [ Tue Jun 13, 2006 8:14 pm ]
Like eone of these?
http://slantsix.org/forum/viewtopic.php?t=18000
Author:  slantdog225 [ Thu Jun 15, 2006 8:55 am ]
He started it... :wink:
