Vacuum Hoses
https://slantsix.org/forum/viewtopic.php?t=18009
Page 1 of 1
Author:  Not_A_Blazer [ Sun Jun 11, 2006 6:50 pm ]
Post subject:  Vacuum Hoses
I am planning the HEI swap on my '87,and while I'm doing that I want to replace the plastic vacuum lines with rubber hoses. I'm probably going to buy a whole roll of hose from the place I work at. My question is what size hose should I buy? Also would the vac. advance hose be the same size as everything else? (I forgot to grab it from the carb donor)
Author:  Not_A_Blazer [ Wed Jun 21, 2006 5:41 pm ]
OK then,anyone have an idea how much I'd need for a '87?
Author:  Reed [ Wed Jun 21, 2006 5:46 pm ]
I think you will need 3/16 and 1/8 diameter hose. I would buy about four feet of each.
Author:  Not_A_Blazer [ Fri Jun 23, 2006 10:08 am ]
Are you sure I'll only need 4 feet,or is that just for the vac advance hose? I want to replace all the plastic garbage hose with rubber hose as well.
